Karen Turk
- SWISS LADY
- St Maarten
- Moody Eclipse 43
- Caribbean
Need quite a few of these, as mine are all failing and Lewmar does not make spares.
Hi Andy! Would you mind sharing the sizes/styles of the new hatches you put in? Were you able to put them right in or did you have to do fiberglass work? Also would you mind sharing the approximate cost? Might need to go down this path as water is getting in from the one with the broken latchI had the same problem and mde the concious decision to replace them with new lewmar hatches. They are the same size.
If you initially replace a few then it will give you some spares.
