Moody 47 Moody 47 1984 for sale
David Carey
Temporary Member
Moody 47
$140,000 USD - available ASAP - currently located in Montenegro
VAT not paid
Australian registered
We are a family of 5, including three boys, who bought our 1984 centre cockpit Moody 47 sight unseen back in Nov 2017. Luckily she was exactly as described and she has never given us any trouble since. She has two cabins complete with three single beds, a queen-size aft cabin and two heads. Since owning her we have sailed throughout the Caribbean, across the Atlantic Ocean and throughout the Med. She is a solid bluewater cruiser, spacious for her age and has been a safe and reliable family home for the past 4 years. We are selling to upgrade to a catamaran as we are soon to have 2 teenagers on board who need their own space. The boat has been maintained by an ex-aircraft technician and many upgrades and checks have been done since owning the boat including a re-rig, new chainplates, a recent keel bolt inspection and replacement of keel bolt backing plates and nuts. She underwent an insurance survey only a few months ago (she got a perfect bill of health, happy to provide a copy), has a new bottom job, recent rigging and sails, low engine hours, a large amount of solar and wind power, a watermaker, and a reliable dinghy and engine. This boat is ready to sail back across the Atlantic tomorrow if need be, and that was our plan until just recently when we decided to buy a catamaran instead. You can view our story on Facebook where we have written about the past four year @Sailing to Roam and Instagram @sailing_to_roam
To arrange a call please send a messenger DM, WhatsApp +596696770132 or email us on erinndave@hotmail.com
Here is a Dropbox folder of photos:
https://www.dropbox.com/sh/ma5z7gr6yq1yxy6/AAAFNyzcx3GeroYVTGDHokg4a?dl=0
Electronics
Digital Yacht AIT 2000 class B AIS
Standard horizon matrix VHF with built-in AIS new 2018
Icom 801e SSB with P4 Dragon modem
Autopilots - Two complete and independent ray marine autopilot systems fitted. ST6002 with linear actuators fitted to rudder control quadrant. Two control heads, two actuators, two computers, two rudder feedback units, two compasses. This allows for a complete autopilot backup system at the flick of a main switch at the AC control panel.
440 amp Vetus AGM house battery bank new 2021
Victron battery monitor, amps, volts etc
Dual diesel/water gauge
Various 220v AC sockets throughout, with associated circuit breakers, shore power polarity check lights and associated wiring
2 x lead acid Vetus batteries in battery box above forward bow thruster, linked to victron phoenix combi 75 amp charger and alternator
Generator start battery in box
E120 ray marine chart plotter with radar overlay and ais linked to it
HD radar Raymarine
St50 windspeed and direction, boat speed and depth instruments in cockpit
12v repeater screen at nav station down below repeats what’s on chart plotter above
Victron Phoenix 1600w inverter combo 75 amp charger with remote panel including shore power limiter dial
USB charger at nav and in cockpit
Masthead and deck level led navigation lights, led anchor light
Ground Tackle
Rocca 33kg main anchor, spare Bruce 30kg anchor
85m of 10mm galvanised chain, new 2020.
Lofrans Tigress windlass
Wind/Solar
1000w solar with 2 Victron charge controllers,
Rutland wind generator mounted on aft solar arch, matched to Rutland charge controller and separate control head box allowing amp in monitoring
Aerogen 6 wind turbine mounted to aft solar arch, with dump resistors under nav to control voltage
Galley
Gas solenoid and dedicated vented gas locker in aft laz, on-off switch in galley with indicator light, one 12kg Italian gas bottle, one Spanish 12kg bottle, one 3kg campingaz bottle, all in as new condition.
Magma gas bbq grill mounted on the rail, new 2022
Top loading fridge in galley, cooling unit in aft cabin wardrobe, new water pump fitted 2021, nice cold fridge, no freezer.
Gas cooker oven, two burner
Galley stocked with all cutlery, pots pans etc
Toaster runs off inverter
Engine
Main engine start battery under nav seat
Yanmar 4JH4AE diesel with low hours, approx 3000 Very reliable, blows no smoke and starts first time.
New alternator fitted 2021, new heat exchanger unit with internal stack fitted 2021. All oil and fuel services carried out as per manufacturers’ recommendations.
Cutlass bearing replaced 2022,
max prop two-blade classic. Cruising speed approx 7 knots at 2000rpm
Twin Racor 500fg fuel filters fitted prior to main engine fuel filter,
10-micron filters fitted
Fischer panda 6000nd diesel generator mounted in engine room with remote panel, running but doesn’t produce AC power. Low hours.
Ribe Portable petrol generator stored on deck, 3500watts, runs water maker and battery charger via shore power cord, new 2020 150hrs on it
Plumbing
Seacocks are a mix of original Blakes units (fully serviced) and Grocco baseplate and ball valves with G10 backing plates fitted new 2018,
Vetus strainers fitted to main units
Jabsco Electric lite n flush toilet aft, Jabsco manual toilet forward.
On deck fresh water rinse-off hose fitted
2 x 250 litre custom fresh water tanks under saloon seats
Water pressure via pressure switched 12v pump
Shower in aft toilet,
jabsco electric grey water pump pumped overboard
Blackwater soft tank plumbed to the front toilet with a y valve.
Ac powered washing machine in forward sail locker, runs off inverter
Sea fresh water maker (AC Powered) 1.5 litres per minute
Hot water system from engine and shore power
Sails/Canvas
Mainsail fully battened new 2019
Headsail new 2022
Staysail fitted 2004 ok condition
Spare headsail in ok condition
Spare headsail needs rebuild
Spinnaker pole (length can be adjusted) with matching car system on front of mast
Three spare halyards fitted at the mast
Mast slab reefing system, 3 reefs in main
Lazy jacks ok condition, dodger in ok condition, Bimini in ok condition
Rigging
New running rigging 2019
Standing rigging replaced 2019 forestay backstay 2022
New chain plates installed 2019 as well as new chain plate bolts
Seldon 400s headsail furler forestay
Selden 300s furler staysail.
Lewmar 55 manual self-tailing cockpit winches x4
Lewmar 30 manual cockpit winches for mainsail sheet, furling lines and traveller x4
Steering control cables replaced 2018
Cockpit
Teak cockpit floor and seats
New leather steering wheel cover
Compass in binnacle
New Boss MGR150 marine stereo with Bluetooth and 4 speakers, two water proof in cockpit
Vetus Bow 95 Bow Thuster - new solenoids 2021
Dinghy
Yamaha enduro 15hp two stroke outboard, pull start, new 2019.
ZAR mini 10ft rib dinghy, new 2018, some hypalon wear and tear but no leaks
Davits to rear of boat with pulleys
Outboard engine crane and mount
Spare electric outboard with spare prop
Safety
Life rings
2x Fire extinguishers, fire blanket and two automatic fire extinguishers in engine room
Rule 2000 bilge pump with new float switch and high water audio alarm, two manual bilge pumps
6 man life raft new 2018
Cabins/Saloon
Good blankets and doonas
220 volt heater in saloon
Marine air conditioning system
Cannon printer
Saloon couches recovered 2021
Cabin fans throughout
Mix of led low draw fluoro lighting and led cabin lights throughout
Desk setup built in adjacent aft cabin queen bed, room for a laptop
Misc
Large forward sail locker and large aft lazarette
Toe rail converted to timber by previous owner, very attractive
Passerelle
Keel bolts inspected 2022 replaced with new backing plates and nuts, approved by surveyor
Bottom job done three months ago
Diesel tank under aft cabin bed
Lewmar hatches throughout
