Hi Guys. Could anyone give me an indication of how much it would cost to replace the windows on a Moody 38 Mark 2 please which be very much appreciated for any input
There is one or two 'old stock' Lewmar windows knocking around try Ocean Chandlery or eBay. Although unlikely you mighty be lucky to find one, I wasn't!Hi Dick. You are a wealth of information which is very much appreciated. I did think initially that because the existing windows are Lewmar that I would just be able to have them easily replaced with the same but will certainly contact Eagle windows for a price. Many thanks once again. Regards, Peter.
Hello Dick, I want to refurbish my M37 windows, ie replace the acrylic and reseal the acrylic and the joint between the boat and the aluminum frames. Do you know what i should use in the groove where the acrylic sits for a waterproof and shake proof seal please? I have heard of Scapa 3507/17, I am not sure what the 17 stands for. Someone also suggested using butyl tape for the hull to aluminium joint. Thank you .When you say ‘new’ windows and hatches the usual job done on a boat if that era is to replace the acrylic glazing, assuming the frames are still good in all cases.
Sure you can buy complete new hatches, and prices are readily available online. But replacement windows complete with frames would almost certainly need to be specially made.
I suggest you get in touch with a specialist window refurb company like Eagle Boat Windows, they should be able to give you a pretty accurate idea of likely costs of reglazing.
Hi guys.This sort of question is best raised in the main Technical Information forum. However, why not talk to someone like Hadlow Marine, Sea Clear or Seaglaze and find out what they use or recommend?
