James Ward
- SEA DRAGON
- Portsmouth
- Moody 38 (2000s)
- Solent
Moody 376 For Sale
Year 1989 Length 37’11ft Built Marine Projects Price £60,000
The Moody 376 is a powerful offshore cruiser, easily handled by a couple, with spacious accommodation. This is an excellent example that we have owned for 5 years, it has been extremely well maintained, continually upgraded at great expense and is offered for sale in great condition. She has a Scheel keel (shallow draft), solid windscreen, bow thruster, Eberspatcher heating and a very good inventory.
Year Built 1989
Length 37’11ft
Beam 12’6ft
Max. Draft 4’7ft
Cabins 3
Double Berths 2
Electrical System 12v
Keel Scheel
Engine Volvo Penta MD2003T 44hp shaft drive
Fuel Tank Cap 204L
Water Tank Cap 250L
Displacement 7820kg
Ballast 2950kg
Laying Hampshire, United Kingdom
Accommodation
The layout offers up to seven berths with two double sleeping cabins separate from the main accommodation. In the forecabin, V berth with infill and stowage under. Open hatch to foredeck. Hanging locker. Ensuite heads compartment to starboard with marine manual flush toilet, shower and washbasin. There is also access to the forward heads from the saloon. Additional hanging locker opposite.
In the saloon, dinette to starboard with settee berth opposite. Fixed table with drop leaves. Opening hatch to deck. Chart table to starboard with quarter berth behind and galley opposite. Neptune stainless steel two burner gimballed gas cooker with grill and oven. Twin stainless steel sinks with pressurised hot and cold water system. 250L freshwater capacity. Refrigerator.
Walk through to aft cabin, quarter berth outboard and engine access opposite. In the aft cabin, good sized double berth (with memory foam mattress) to port with settee opposite. There is an infill to make this a double berth across the boat as well. Ensuite heads compartment with electric marine toilet, shower and washbasin.
Radio/CD Player with Bluetooth media. Eberspatcher D4L diesel fired hot air central heating. Hot and cold pressurised fresh water system (immersion and engine heating). 250L water capacity. Grey draylon type fabric upholstery. Curtained.
Mechanical Systems
Located in a separate engine space below the cockpit, with good access. 1989 Volvo Penta MD2003T three cylinder 44hp turbo charged marine diesel engine (new Turbo 2021). Electric start. Fresh water cooled via heat exchanger. Shaft drive too Featherstream three bladed feathering propeller. New shaft fitted in 2012 with Tides Marine SureSeal. Single lever control. 204L fuel capacity. 6 knot cruising speed. Maximum speed under power 8 knots. The engine has been annual serviced by a Volvo Penta dealer. Service history available.
Lewmar Bow Thruster
Electrical Systems
- 4x 12v batteries (emergency engine start and 3 domestic, all replaced 2021)
- Alternator charging (new 2021)
- Galvanic isolator
- Victron Energy MultiPlus 2000VA battery charger and invertor (new 2021)
- Immersion heater (new 2017)
Masthead rigged sloop, deck stepped. Anodised aluminium mast and boom by Kemp Spars (Selden Masts). Stainless steel standing rigging (new 2012). New running rigging (new 2019). Selden in-mast mainsail furling. Furlex headsail furling system. Removable inner forestay. Four Lewmar sheet winches. Three Lewmar secondary winches. Lewmar main furling minch. Spinnaker pole. Kemp Rod Kicker.
- Furling mainsail – One Sails – new 2012
- Furling blade job – One Sails – new 2012
- Furling genoa – Lucas Sails – V good condition
- Cruising chute with snuffer – One Sails – fitted 201
Deck Equipment
- Danforth anchor with 30m chain
- Seawolf Royal 520 manual anchor windless
- Stainless steel pulpit and pushpit, stations and guardwires with gates (new 2013)
- Teak coachrood grabrails
- Tecsew sprayhood (new 2021)
- Tecsew bimini/enclosure (new 2021)
- Binnacle cover
- Stainless steel boarding ladder
- Eight fenders with warps (six fender baskets)
- All windows replaced with new acrylic and reseated (new 2021)
Navigation Equipment
- Plastimo steering compass
- Garmin GMI20 depth sounder (new 2019)
- Garmin GMI20 boat speed and log (new 2019)
- Garmin GMI20 windspeed and direction (new 2019)
- Garmin 300i VHF (new 2019)
- Garmin 4008 chart plotter / GPS with radar on binnacle, within separate 12v supply
- Autohelm autopilot
- Masthead and deck level navigation lights
Safety Equipment
- CO2 detector
- Various fire extinguishers including in engine room
- Deck light and cockpit harness points
- Horseshoe liftbuoy with floating light
- Liferaft cradle on stern
- Emergency tiller
- Manual bilge pump
Contact: 07999 282930 (please leave a voicemail or send a text message if I am unavailable and I will come back to you), or email mckendry@outlook.com
