David A Evans
Temporary Member
I'm just about to buy a Moody 31 but the survey states that the chainplates are leaking. The surveyor said that this could cause problems with the balsa core and worse case scenario could cause the rig to fail!!
So question is is leaking shroud chainplates common in Moody 31 and does it cause major problem?. Do other owners cut inspection hatches into deck or cabin joinery to keep an eye on these?
David
David
