Spent a couple of hours on a 376, followed by a brief 2-3 knot sail. Very little motoring involved. It checked out well on first glance, odd things like plastic panels for the headliner as all the wiring had been replaced, requiring headliner removal. Seem to be engine issues, will overheat if run at full clip, but "will run all day at 5 knots" This is with a brand new Bowman heat exchanger and engine "refit" with a water pump replaced along the way. Owner said he was considering a muriatic acid flush, but my understanding is the T80 Thornycroft engines are prone to corrosion through the wet liners, hence any acid flush to me is risky. And not one dealer outside of the UK. So my question is what other engines "drop in" without major refitting of engine supports and realignment of shaft or re-propping? Lots of fan belt fluff over the engine, an aftermarket Leece alternator in place, both belts chafing it seems. Otherwise, items such as electronics are minimal and poor when new much less a decade later. But that's minor compared to swapping out an engine. Caulking around chain plate covers still pliable and deck nearby flat. Like the layout overall, we're in a cooler climate, east coast of Canada, so the cozy cockpit isn't a bad feature. Found the V berth/cabin to be a bit snug too. But the engine alone is enough to put me off, so any advice regarding replacement would be appreciated. Tim
