For Sale Ford 1.8XLD 50HP 1995
MALAYA
Licata, Italy
Moody 425
Mediterranean
Because of our extended cruising plans we are renewing our engine. The engine is in good working order with the following remarks:
1. Leaking front crankshaft seal. This is a tiny leak. The seal is easier to replace when the engine is out of the boat (the reason why we have not done it). We have the spare seal which will come with the engine.
2. It has 2 12V 55A stock alternators attached, driven by 2 separate single V belts.
3. Connections for calorifier
4. Bowman FM180 heat exchanger
5. Control panel with rpm, oil pressure and water temperature gauges.
6. Including Hurth HBW100 gearbox.
7. Including Haynes shop manual
8. New tensioning belt set, including tensioner
PO had engine installed early 2022 and hours run are 1703 (lifetime).
1500 euro.
I will soon place some pictures. Location is Malta.
Sailingmalaya@outlook.com
As promised herewith the pics
1 more.
I also have a video of how it runs before we took the boat out the water last week, but cannot post it here I believe. I can email it upon request.
